NDI
Problem with an NDI source in vMix
Joined: 6/4/2016(UTC) Posts: 14  Location: Warsaw, Poland Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
Hello I'm running a CasparCG server that outputs an iVGA/NDI stream (720p25). I can succesfully capture it using the NDI Video Monitor but I encounter a problem when using this stream as an input in vMix (also set to 720p25). I get only top half of the picture, stretched vertically. Here is how it looks in Video Monitor http://imgur.com/pwHIptN, and what i get in vMix http://imgur.com/tOC9bd9. Moving and scaling the input does not reveal the rest of the picture, only the top half is visible. Tried turning off and on again, and reinstalling everything ;) It would be great if anybody had some clues how to fix it. Thanks!
Verify on the Settings for that Input that the Position Zoom is set to 1.
- Tom
Make sure you are running the most current version for all NDI based tools.
Kane Peterson NewTek
NDI
