krzychuz
#1 Posted : Saturday, June 4, 2016 10:40:28 AM(UTC)
krzychuz
Hello
I'm running a CasparCG server that outputs an iVGA/NDI stream (720p25). I can succesfully capture it using the NDI Video Monitor but I encounter a problem when using this stream as an input in vMix (also set to 720p25). I get only top half of the picture, stretched vertically.
Here is how it looks in Video Monitor http://imgur.com/pwHIptN,
and what i get in vMix http://imgur.com/tOC9bd9.
Moving and scaling the input does not reveal the rest of the picture, only the top half is visible.
Tried turning off and on again, and reinstalling everything ;)
It would be great if anybody had some clues how to fix it.
Thanks!
sinc747
#2 Posted : Saturday, June 4, 2016 11:19:26 AM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Verify on the Settings for that Input that the Position Zoom is set to 1.
- Tom
krzychuz
#3 Posted : Saturday, June 4, 2016 11:26:45 AM(UTC)
krzychuz
Everything is set like this http://imgur.com/Yiv7s7V, and as I said, playing with these options did not reveal the missing half.
EDIT: Same thing happens to a source produced by NDI Test Patterns app http://imgur.com/F5qXEG2
kane
#4 Posted : Sunday, June 5, 2016 3:23:30 PM(UTC)
kane
Make sure you are running the most current version for all NDI based tools.
Kane Peterson
NewTek
