Hello, I solved the problem, I got an i3 and now I want to open my online internet television with Vmix program. Vmix tv program contains function? Or if you put in future versions Vmix. Well, I have this function for starting a movie for example, advertising, apo return to film everything automazit with the program outputs at fixed hours. For example at 10:00 enter a movie at 10:00 ap.png enter overlay, and overlay 11:300 movie comes ap.png the same. About something like that I want.
Regards, Alin
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
vMix is not designed to be used as an automated television station at this time. In theory, a 3rd party program could be built that automates vMix in this way but it isn't something we are looking into at the moment.
Martin vMix
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi Alin!
I'm working on a software that works with vMix, and I'm hearing for functions to add. If you describe exactly the functions may be i can help you. I think your problem it's to automatize the overlays with the names of the movies (in this example).. because you should make a playlist, that defines you the time... Well, i can do this: you can make a title (a generic PNG) for the next movie, and store in my software the names, so it can be changed in the next movie in an automated way, programming in wich moment (time) you want to show it... Regards!
