Httprequests & API issues (SLOWING down)
Hi all
Need some advice.
Sending httprequest from a client program to get data to vMix titles seems at some point to slow down or worse temporarly stop my client program especially multiple fast updating titles values. ( even simply sending multiple values to multiple fields one notices delays between each )
For the experts could this be related to response times of these requests made ?
In an extreem effort I like to send stopwatch (not clock) data to a title
ps client is written in vb.net
Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
doggy wrote:Hi all
Need some advice.
ps client is written in vb.net You can change the request timeout. Here's what I do (changes the text of a title): Code: Public Function setvMixText(ByVal titleKey As String, ByVal inTitle As String, ByVal setText As String) As Boolean
Try
' Create a request for the URL.
Dim request As WebRequest = WebRequest.Create("http://localhost:8088/API/?Function=SetText&Input=" & titleKey & "&SelectedName=" & inTitle & "&Value=" & setText)
' If required by the server, set the credentials.
request.Credentials = CredentialCache.DefaultCredentials
request.Timeout = 1000
' Get the response.
Dim response As WebResponse = request.GetResponse()
' Display the status.
Debug.Print(CType(response, HttpWebResponse).StatusDescription)
' Get the stream containing content returned by the server.
Dim dataStream As Stream = response.GetResponseStream()
' Open the stream using a StreamReader for easy access.
Dim reader As New StreamReader(dataStream)
' Read the content.
Dim responseFromServer As String = reader.ReadToEnd()
' Display the content.
Debug.Print(responseFromServer)
' Clean up the streams and the response.
reader.Close()
response.Close()
Return True
Catch ex As Exception
Return False
End Try
End Function
 1 user thanked tesn for this useful post.
