#1 Posted : Thursday, June 2, 2016 9:58:16 AM(UTC)
Hi all
Need some advice.
Sending httprequest from a client program to get data to vMix titles seems at some point to slow down or worse temporarly stop my client program especially multiple fast updating titles values. ( even simply sending multiple values to multiple fields one notices delays between each )
For the experts could this be related to response times of these requests made ?
In an extreem effort I like to send stopwatch (not clock) data to a title
ps client is written in vb.net
tesn
#2 Posted : Thursday, June 2, 2016 12:17:38 PM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
doggy wrote:
Hi all
Need some advice.
You can change the request timeout. Here's what I do (changes the text of a title):
Code:
 Public Function setvMixText(ByVal titleKey As String, ByVal inTitle As String, ByVal setText As String) As Boolean
        Try
            ' Create a request for the URL.
            Dim request As WebRequest = WebRequest.Create("http://localhost:8088/API/?Function=SetText&Input=" & titleKey & "&SelectedName=" & inTitle & "&Value=" & setText)
            ' If required by the server, set the credentials.
            request.Credentials = CredentialCache.DefaultCredentials
            request.Timeout = 1000
            ' Get the response.
            Dim response As WebResponse = request.GetResponse()
            ' Display the status.
            Debug.Print(CType(response, HttpWebResponse).StatusDescription)
            ' Get the stream containing content returned by the server.
            Dim dataStream As Stream = response.GetResponseStream()
            ' Open the stream using a StreamReader for easy access.
            Dim reader As New StreamReader(dataStream)
            ' Read the content.
            Dim responseFromServer As String = reader.ReadToEnd()
            ' Display the content.
            Debug.Print(responseFromServer)
            ' Clean up the streams and the response.
            reader.Close()
            response.Close()
            Return True
        Catch ex As Exception
            Return False
        End Try
    End Function
thanks 1 user thanked tesn for this useful post.
stigaard on 6/2/2016(UTC)
