Get the Vmix timer to go past 50 minutes?
Hello.
I have a soccer production later today and trying to use the Vmix built-in timer for the clock. The only problem I have is that it doesn't go past 50 minutes. Is there a setting or a work around for this? Would need it go up to 90-99.
Thanks.
@ StreamTeamChris
Yes, I believe that when you set the timer to 1:30:00 and set the display to mm:ss it will show 90:00.
Hope that helps.
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
StreamTeamChris wrote:Hello.
Thanks. Just put on first field on setup for timer a duration to 03:00:00 Then it will go past 50, past 90 past 120 minutes
