StreamTeamChris
#1 Posted : Wednesday, June 1, 2016 6:33:02 AM(UTC)
StreamTeamChris
Hello.
I have a soccer production later today and trying to use the Vmix built-in timer for the clock.
The only problem I have is that it doesn't go past 50 minutes. Is there a setting or a work around for this?
Would need it go up to 90-99.
Thanks.
#2 Posted : Wednesday, June 1, 2016 6:39:04 AM(UTC)
@ StreamTeamChris
Yes, I believe that when you set the timer to 1:30:00 and set the display to mm:ss it will show 90:00.
Hope that helps.
Siroki
#3 Posted : Wednesday, June 1, 2016 9:54:01 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
StreamTeamChris wrote:
Hello.
Thanks.
Just put on first field on setup for timer a duration to 03:00:00
Then it will go past 50, past 90 past 120 minutes
