alin18
#1 Posted : Thursday, August 30, 2012 10:34:32 AM(UTC)
alin18
Hi,i have a aproblem with vMix V4 2012.
Always gives me this error when I try to add clips:
1. DragDrop.DragDrop.I_VMR
Could not Configure VMR.
2.I_VMR
AddNewInput.I_VMR
Creating an instance of the COM component with CLSID {51B4ABF3-748F-4E3B-A276-C828330E926A} from the IClassFactory failed due to the following error: 80040273.
Can someone help me with this problem?
Alin
#2 Posted : Thursday, August 30, 2012 11:51:07 AM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
Hi Alin,
That error message indicates a component is missing from your system, specifically the Video Mixing Renderer 9 which is a part of Windows Media Player.
To fix this, try installing the latest service pack for windows and the latest version of windows media player.
alin18
#3 Posted : Friday, August 31, 2012 10:17:34 AM(UTC)
alin18
Hi Martin,
I reinstalled the operating system and the same problems persist:
2.I_VMR
AddNewInput.I_VMR
What can be the solution to this problem?
I did a test now 2:00 and I installed an older version of Vmix v3 and it worked perfectly, but version 4 does not work at all to introduce media files
Alin
#4 Posted : Friday, August 31, 2012 11:57:49 AM(UTC)
What graphics card do you have? Sounds like it needs to be upgraded.
v4 uses more advanced 3d features.
alin18
#5 Posted : Friday, August 31, 2012 1:20:59 PM(UTC)
alin18
Use Radeon 9520 256 MB shard series, DirectX 9.0b and to make it work Vmix use a plugin called SwiftShader (emulator pixel and vertex shader 3.0).
Emulated in software mode works fine, starts capture everything, but not placed clips because rendering engine.
#6 Posted : Friday, August 31, 2012 10:38:56 PM(UTC)
Unfortunately software like SwiftShader is not supported so you will need to upgrade to a better graphics card.
