vMix Virtual Control Surface 2.1 Available Now!
Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
Version 2.1 of the vMix Virtual Control Surface is now Available in the Apple App Store for the iPad! The was formerly known as vDesk This version has be redesigned and has much better performance across all generations of iPads. You can get the app at the link below! https://itunes.apple.com...surface/id978932322?mt=8vMix CS is a software control surface for controlling the video switching program vMix. This app enables you to control vMix from anywhere within your network. vMix CS also provides the feel of a traditional hardware switcher. Simply press the IP address within vMix CS and type in the IP address of the computer running vMix. vMix Virtual Control Surface Features: -12 preview buttons -12 program buttons -12 overlay buttons -12 audio input faders -12 mute input buttons -12 audio meters (DBFS) -4 DSK buttons to control up to 4 overlay channels -4 transition buttons -4 user programmable buttons (programmed within vMix as F1, F2, F3, F4) -Master / Bus A / Bus B audio fader -Master / Bus A / Bus B mute button -Record, Stream, External, FadeToBlack, and Take buttons -Smooth T-Bar ******NOTE****** The host vMix computer must have its network set to "Home". Setting this to "Work" or "Public" will block vMix Virtual Control Surface from connecting to vMix. This can be changed by right clicking the network icon on the bottom right of windows and selecting "Open Network and Sharing Center". In the Network and Sharing Center, the network that you are currently connected to will be displayed along with an icon. Under the name should list the current security setting. It will either list "Home", "Work" or "Public". To change this setting, click on the link below the network name and a new window will pop up. In this new window, select "Home Network" In Windows 10 this needs to be set to Private
 3 users thanked thecloudmediagroup for this useful post.
thecloudmediagroup wrote:******NOTE****** The host vMix computer must have its network set to "Home". Setting this to "Work" or "Public" will block vDesk from connecting to vMix. This can be changed by right clicking the network icon on the bottom right of windows and selecting "Open Network and Sharing Center". In the Network and Sharing Center, the network that you are currently connected to will be displayed along with an icon. Under the name should list the current security setting. It will either list "Home", "Work" or "Public". To change this setting, click on the link below the network name and a new window will pop up. In this new window, select "Home Network" This may work with Windows 7 and perhaps 8, but in Windows 10 you only have "Private" and "Public". Switching has also changed: http://www.tenforums.com...public-windows-10-a.html
 2 users thanked ovinas for this useful post.
An iPhone version of the app is also in the works and should be released soon! How many would use the app for iPhone when it is available?
 1 user thanked thecloudmediagroup for this useful post.
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Fantastic app! :) I bought it earlier today and had a quick test with it and it works really well.
Is there anything I can do to minimise the delay when switching between the audio and the video page? Some times it will take several seconds to switch (iPad Air)
Do you have any plans to add features like being able to change text in titles and changing settings for the fullscreen outputs?
Thanks! :)
Edit: depending on if you're making the iPhone version available as a universal app (ie. no need to buy it again), then I'll probably end up trying it and possibly using it if the buttons aren't too small.
Lennart wrote:Fantastic app! :) I bought it earlier today and had a quick test with it and it works really well.
Thanks! :)
Edit: depending on if you're making the iPhone version available as a universal app (ie. no need to buy it again), then I'll probably end up trying it and possibly using it if the buttons aren't too small. Glad you like the app! It should switch nearly immediately. How long does it take on your iPad? We do have plans on additional features including a potential live multiview video feed to the app that can be used as a touchscreen switcher (via NDI) as well as 24 inputs and integrating title editing and adding in vMix social. All plans for right now but we will keep you updated as we progress:)
thecloudmediagroup wrote: Glad you like the app!
I think it was a temporary problem, haven't been able to replicate the problem since. Sounds great :)
Joined: 6/6/2015(UTC) Posts: 21 Location: South Africa
This looks great, pity there's no Android Version! (for those of us who live in countries where mac's arne't the 'only' devices around!)
Kibim wrote:This looks great, pity there's no Android Version! (for those of us who live in countries where mac's arne't the 'only' devices around!) Andoid version is in the works. It's not easy to port the app to the Android platform. The iOS platform is more user friendly with Swift. However with Apple making Swift open source, there may be a solution soon to porting the app over to Android more easily. Definitely planning on the app in the future!
 2 users thanked thecloudmediagroup for this useful post.
vMix Virtual Control Surface 2.1 is now available in the app store! -Added audio meters to audio inputs, aux buses and master busv (DBFS) -Updated audio fader graphic -Fixed crash if audio tab was selected before video tab after connected
Thanks: 10 times Was thanked: 4 time(s) in 4 post(s)
thecloudmediagroup wrote:An iPhone version of the app is also in the works and should be released soon! How many would use the app for iPhone when it is available? Many of us have been waiting on the Windows version, and will use that when released.. Any word on that?
Thanks: 1 times Was thanked: 6 time(s) in 6 post(s)
I have a problem, pressing the program button, the mixing is done but does not start the video. Only the first frame appears.
What can be the cause?
Rank: Guest
Groups: Guests
This looks so nice.....When are we going to get the Windows version.....
Joined: 7/23/2013(UTC) Posts: 133  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
How about including the program monitor as NDI receiver in the video mixer screen?
That would make the Control Surface as a wireless vMix terminal without a need to sit in front of the screen.
Originally Posted by: Ramó  I have a problem, pressing the program button, the mixing is done but does not start the video. Only the first frame appears.
What can be the cause? Using the program button will only make the clip active in the "Live" window but will not play the clip. If you want to play the clip you would need to click the preview button and use one of four transition buttons or the "Take", "Auto" buttons or the T-Bar. We may add the feature to automatically play the clip in the future so stay tuned.
KJ4AWR wrote:thecloudmediagroup wrote:An iPhone version of the app is also in the works and should be released soon! How many would use the app for iPhone when it is available? Many of us have been waiting on the Windows version, and will use that when released.. Any word on that? We are waiting for some development progressions in the Microsoft Bridge program within Visual Studio that will allow us to easily port Swift to Visual Studio for a smooth transition. The Apple WWDC conference is also coming up where they may release Swift 3.0 which may also include some advancements in the porting process to both Windows and Android. I know its been a long process but we want to make sure that the port is a high quality port and has a smooth workflow between the iOS versions and the Windows/Android versions. Thank you for your patience in the process. We want to get a Windows/Android version in your hands ASAP.
jip wrote:How about including the program monitor as NDI receiver in the video mixer screen?
That would make the Control Surface as a wireless vMix terminal without a need to sit in front of the screen. This is the plan for the future version of the app. Currently the NDI libraries do not have an ARM processor (mobile) version for iOS devices yet. This is in the works through NewTek and we will look implement this touchscreen video mixer to the app as soon as that library is made available.
thecloudmediagroup wrote:KJ4AWR wrote:thecloudmediagroup wrote:An iPhone version of the app is also in the works and should be released soon! How many would use the app for iPhone when it is available? Many of us have been waiting on the Windows version, and will use that when released.. Any word on that? We are waiting for some development progressions in the Microsoft Bridge program within Visual Studio that will allow us to easily port Swift to Visual Studio for a smooth transition. The Apple WWDC conference is also coming up where they may release Swift 3.0 which may also include some advancements in the porting process to both Windows and Android. I know its been a long process but we want to make sure that the port is a high quality port and has a smooth workflow between the iOS versions and the Windows/Android versions. Thank you for your patience in the process. We want to get a Windows/Android version in your hands ASAP. Fair answer- thank you for that. Now.. to go start beating on Microsoft's door for good porting tools, and Apple's for Swift 3.0 porting abilities. :)
KJ4AWR wrote:thecloudmediagroup wrote:KJ4AWR wrote:thecloudmediagroup wrote:An iPhone version of the app is also in the works and should be released soon! How many would use the app for iPhone when it is available? Many of us have been waiting on the Windows version, and will use that when released.. Any word on that? We are waiting for some development progressions in the Microsoft Bridge program within Visual Studio that will allow us to easily port Swift to Visual Studio for a smooth transition. The Apple WWDC conference is also coming up where they may release Swift 3.0 which may also include some advancements in the porting process to both Windows and Android. I know its been a long process but we want to make sure that the port is a high quality port and has a smooth workflow between the iOS versions and the Windows/Android versions. Thank you for your patience in the process. We want to get a Windows/Android version in your hands ASAP. Fair answer- thank you for that. Now.. to go start beating on Microsoft's door for good porting tools, and Apple's for Swift 3.0 porting abilities. :) That's exactly what we are doing:) Our desire is to have it written a single time and then ported to different platforms each time rather than creating the app from the group up for each platform and then adding the features to each version every time there is an update. The Microsoft Bridge tool is getting close to working but we haven't quite gotten it to work. We have converted it to Visual Studio with the tool but are running into errors when building it. It's getting there!
