Father Jose
#1 Posted : Monday, May 9, 2016 8:31:54 PM(UTC)
Father Jose
Rank:: Newbie
I'm a "one person orchestra", record, control the computer and serve as the "actor". I record Masses, inspirational and prayer videos. For the inspirational videos I follow an script, so I need to control vMix as I also read the script at the screen. Any advise anyone can offer will be GREAT!
Thanks,
Father Jose
Cpilcher
#2 Posted : Monday, May 9, 2016 8:42:49 PM(UTC)
Cpilcher
What Graphics card are you using? There are a few different options to give you a 2nd monitor. If your graphics card has a 2nd connection for a monitor that would be the easiest. I have a GTX 970 by NVidia and have 4 monitors being used with my setup.
If you give a little more info on your setup I could give you more detailed instructions.
Chuck
thanks 1 user thanked Cpilcher for this useful post.
Father Jose on 5/9/2016(UTC)
Father Jose
#3 Posted : Monday, May 9, 2016 8:50:09 PM(UTC)
Father Jose
Rank:: Newbie
Thank you Chuck,
I'm just using a Win 7 PC with the factory installed options. Your advise is really appreciated. What should I do? How can you control the different monitors?
Father Jose
Cpilcher
#4 Posted : Monday, May 9, 2016 8:59:26 PM(UTC)
Cpilcher
It will depend on what video connections you have available on the back of the PC. Most will have a VGA / DVI connection as well as an HDMI port. Are you familiar with these terms? Also you could post an image of the back of your PC and I can see what options you have available.
Chuck
w14
#5 Posted : Tuesday, May 10, 2016 4:25:46 AM(UTC)
w14
Have you thought about using an ipad or android tablet and getting hold of DataVideo's free DV Prompter software? The ipad version is here:
https://itunes.apple.com...rompter/id410825555?mt=8
and the android version here:
https://play.google.com/...ter.iprompt&hl=en_GB
Here's Davavideo's overview video:
