Yes. This would be very handy. At present record start stop gets one file per press of the record button. At the end of an event, I have lots of files that I then have to load into a time line editor and sting together. Very time consuming. After an event I just want to pack up, sit down and open an esky. :)
Joined: 4/20/2015(UTC) Posts: 6 Location: Lake City, MN USA
+1!! I've begun evaluation of vMix in place of another software mixer/streamer and I really like it a lot. However, without the ability to pause recording to wait for an event to take place and then restart the recording without creating a new file and thus requiring post processing, I cannot make use of this program. Are there any plans to implement a Record Pause capability in the near future? I see this request was made in Feb 2014 and no response indicated. Regards, CWirtanen
 1 user thanked cwirtanen for this useful post.
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
As alternative, an option to append video (with same parameters) to an existent file. This is possible in Transport Stream (.ts)
Joined: 12/11/2013(UTC) Posts: 2 Location: California
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Pause or append feature would be awesome. I shoot quite a few meetings which often go long and include breaks, pausing or appending would be the bomb to eliminate post processing.
 1 user thanked jjensen for this useful post.
Joined: 5/3/2016(UTC) Posts: 28 Location: United Kingdom
+1
yes would cut down post processing time.
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
cwirtanen wrote:+1!! I've begun evaluation of vMix in place of another software mixer/streamer and I really like it a lot. However, without the ability to pause recording to wait for an event to take place and then restart the recording without creating a new file and thus requiring post processing, I cannot make use of this program. Are there any plans to implement a Record Pause capability in the near future? I see this request was made in Feb 2014 and no response indicated. Regards, CWirtanen cwirtanen new files are not always a bad thing. Separate files can keep you from losing the entire recording should something go terribly wrong. ~George
Thanks: 21 times Was thanked: 11 time(s) in 9 post(s)
+1 I would like to pause recording as well. Often you have short files, but an event can be held up, and sometimes music is played, which becomes a copyright issue. Being able to pause the recording would save a lot of post processing.
Joined: 1/15/2017(UTC) Posts: 45 Location: Exeter, UK
Thanks: 17 times Was thanked: 1 time(s) in 1 post(s)
Thanks: 5 times Was thanked: 8 time(s) in 8 post(s)
 1 user thanked kol0 for this useful post.
Joined: 12/16/2016(UTC) Posts: 9   Location: Mount Rose
A Pause on Recording would be great. I live stream live music events and do not want to record Intermissions and Set Changes.
+1
Yes please...like other said. cut down on post editing. Also add Shortcut to "unpause" a recording with Triggers!
Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
Thanks: 24 times Was thanked: 6 time(s) in 5 post(s)
+1 same reason as others - have a file that can be uploaded as is.
