Chrome Capture - Black Screen
Hey guys!
I am running 17.0.0.77 x64 and when I add a local capture input with Chrome as the source I simply get a black screen. Up until a few days ago this was working fine. Obviously there may have been an update with my Nvidia drivers etc, but I can't find any obvious source of the issue.
I am open to any ideas, or any diagnostics I can look at to get a better feel for the issue.
Thanks!
Ken
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
 1 user thanked Cpilcher for this useful post.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
You're right, the latest Google Chrome update seems to have prevented local desktop capture from capturing the window directly. As a workaround you could capture the entire display instead, use firefox or use the web browser input until I can work out what they might have changed.
admin wrote:You're right, the latest Google Chrome update seems to have prevented local desktop capture from capturing the window directly. As a workaround you could capture the entire display instead, use firefox or use the web browser input until I can work out what they might have changed.
Thanks, I'll give that a try. Ken
Just as a side note, desktop capture seems to fail if I fullscreen Chrome or Edge. after a few frames the capture stops and freezes. If I do NOT fullscreen the video player (usually Youtube) then capture seems to run normally. Ken
