samuraiken
#1 Posted : Wednesday, May 4, 2016 3:53:19 PM(UTC)
samuraiken
Hey guys!
I am running 17.0.0.77 x64 and when I add a local capture input with Chrome as the source I simply get a black screen. Up until a few days ago this was working fine. Obviously there may have been an update with my Nvidia drivers etc, but I can't find any obvious source of the issue.
I am open to any ideas, or any diagnostics I can look at to get a better feel for the issue.
Thanks!
Ken
Cpilcher
#2 Posted : Wednesday, May 4, 2016 4:06:35 PM(UTC)
Cpilcher
They just updated the Desktop capture. Maybe try this version and see if you still have problems.
http://www.vmix.com/down...MixDesktopCaptureNDI.zip
Edit: But since you are using the local capture this may not be the cause...
thanks 1 user thanked Cpilcher for this useful post.
samuraiken on 5/4/2016(UTC)
#3 Posted : Wednesday, May 4, 2016 4:26:10 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
You're right, the latest Google Chrome update seems to have prevented local desktop capture from capturing the window directly.
As a workaround you could capture the entire display instead, use firefox or use the web browser input until I can work out what they might have changed.
samuraiken
#4 Posted : Wednesday, May 4, 2016 5:09:14 PM(UTC)
samuraiken
Thanks, I'll give that a try.
Ken
samuraiken
#5 Posted : Wednesday, May 4, 2016 5:26:16 PM(UTC)
samuraiken
Just as a side note, desktop capture seems to fail if I fullscreen Chrome or Edge. after a few frames the capture stops and freezes. If I do NOT fullscreen the video player (usually Youtube) then capture seems to run normally.
Ken
