guztavo
#1 Posted : Sunday, August 26, 2012 2:50:02 PM(UTC)
guztavo
Hi Martin!
I'm writing because i want to know if you have a full guide about the API functions. I saw the Help... there is more functions than the exposed? If not, may be a future version could have the option to modify titles texts via API... Just a suggestion that will be able to connect vMix with other softwares without using more titles inputs.
Regards!!!
#2 Posted : Sunday, August 26, 2012 9:00:06 PM(UTC)
guztavo on 8/26/2012(UTC)
guztavo
#3 Posted : Sunday, August 26, 2012 10:06:02 PM(UTC)
guztavo
Thanks Martin!
I saw both links but i didn't read slowly about API.
I'm programmer (Visual Basic and PHP) and i didn't understood the explanation directly (i was waiting for a list of commands).. but with testing i understood.
Thanks!!
vMix is just excellent!
Regards!
guztavo
#4 Posted : Tuesday, October 9, 2012 3:03:06 PM(UTC)
guztavo
Hi Martin!
Here i am again......
I'm writing now just to ask you if there is any way to get information about vMix state over the API..
I.E., the actual input on PGM, or if external output is activated, etc.
Thanks!!
Regards
mh166
#5 Posted : Wednesday, October 10, 2012 5:03:57 AM(UTC)
mh166
At least that one can see:
Code:
<vmix>
  <preview>1</preview>
  <active>2</active>
</vmix>
HTH.
guztavo
#6 Posted : Wednesday, October 10, 2012 10:40:46 AM(UTC)
guztavo
Hi mh166!
I was asking for taking information from vMix. The code that you have posted let you set an input, but if i go to vMix and change the actual input, i can't see that over the API...
My question is about getting info.
Regards!!
#7 Posted : Wednesday, October 10, 2012 7:10:59 PM(UTC)
The info is available by visiting the API url without any parameters.
For example http://localhost:8080/API/
This will return an XML file with information about the various inputs including which are active.
This is also described in the help:
http://www.vmix.com.au/h...veloperInformation2.html
guztavo on 10/11/2012(UTC)
guztavo
#8 Posted : Thursday, October 11, 2012 7:01:54 PM(UTC)
guztavo
Thanks Martin....
I didn't see that page... sorry.
Regards!
Similar Topics
vMix Call API functions (Feature Requests)
by bacu89 1/7/2021 5:46:12 PM(UTC)
All vMix API functions (General Discussion)
by gilar 8/24/2020 11:39:28 AM(UTC)
More API functions (Feature Requests)
by daniel514 1/27/2015 4:12:12 PM(UTC)
