PFBM
#1 Posted : Thursday, April 28, 2016 7:16:23 PM(UTC)
PFBM
HI all !!
I will contiune to ask for it !! :)
VST3 64bits Support on Vmix 18 :)
on master bus out and on each feed.
Cheers,
PFBM
PFBM
#2 Posted : Thursday, June 23, 2016 1:00:02 PM(UTC)
PFBM
sorry but i have to insist on this......
another competitor already has it using a plugin adapter:
" Master VST audio plugin support trough Acon Digital Media Chainer plugin. You can use any VST plugin filter, for example VST audio limiters and compressors "
Please guys..... Please !!
Cheers,
PFBM
thanks 1 user thanked PFBM for this useful post.
daniel514 on 9/29/2016(UTC)
PFBM
#3 Posted : Wednesday, June 29, 2016 9:27:27 AM(UTC)
PFBM
BUMP :)
thecloudmediagroup
#4 Posted : Friday, August 26, 2016 7:18:32 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
+100
There is probably not a feature I could dream of that would be more desirable than vst plugin support. We used to use 8 or more broadcast plugins for audio including Waves MaxxVolume which boosts volume huge without compressing the top end. We used to use Virtual Audio Stream to add plugins but it became a bit of a hastle due to making sure it was open and didn't get closed.
http://ddmf.eu/virtual-audio-stream/
thanks 1 user thanked thecloudmediagroup for this useful post.
PFBM on 8/26/2016(UTC)
PFBM
#5 Posted : Wednesday, September 28, 2016 7:20:30 PM(UTC)
PFBM
Here i go again !! :)
Hello vMix Coders !!!
Cheers,
PFBM
Ittaidv
#6 Posted : Thursday, September 29, 2016 10:14:40 AM(UTC)
Ittaidv
+1 for vst support, it makes life easier afterwards: no more mastering of audio :)
thanks 1 user thanked Ittaidv for this useful post.
PFBM on 10/4/2016(UTC)
PFBM
#7 Posted : Tuesday, October 4, 2016 2:45:50 PM(UTC)
PFBM
Well... i guess... still no vst plugins support on vMix 18.....
Sad.... :(
PFBM
melody
#8 Posted : Thursday, October 13, 2016 8:01:57 AM(UTC)
Rank: Guest
Groups: Guests
+1
nice feature... ;)
melody
PFBM
#9 Posted : Thursday, October 13, 2016 1:52:04 PM(UTC)
PFBM
Still dont understand why there is not one Vmix coders comment about this....
Cheers,
PFBM
melody
#10 Posted : Tuesday, October 18, 2016 7:24:21 AM(UTC)
Rank: Guest
Groups: Guests
PFBM,
this sounds something like multicorder request i made in the past. that took so much time to implement, but in fact vMix was the first software video mixer on the market with that feature, "others" came along the way behind vMix with similar features.
in other side, i understand when the admin wait a little bit to implement some features. there are some important things envolved like feature itself complexity, software stability/compatibility running that feature, feature license, interested users (the most important in some cases)...
to me personaly, VST support is not really a "need", but i can understand your "need"... and new potential users "needs".
the reason i searched for a software like vMix, was because i had "needs" and not the solution, this could be the dilemma of so many people. so i founded vMix, in his early years, and i saw so much potential on it... even vMix was not working exactly as i expected, i started to help Martin on improving his software, giving my sugestions as other users did. now we have a new diferent vMix, more stable, more eficient, more anything you imagine.
i hope this feature can be implemented to support other users needs, as it support my needs all this time.
cheers
PFBM
#11 Posted : Wednesday, October 19, 2016 4:17:57 PM(UTC)
PFBM
Hope is the last thing to go.....
Please put a vst bridge on vmix !!
Kind regards,
PFBM
Digitalson
#12 Posted : Tuesday, November 15, 2016 12:55:17 PM(UTC)
Digitalson
Groups: Guests
And maybe external hardware plugins also,I would like to see more output routing options ,cause then u can mix audio in another program,that's what I'm doing now,I run the audio in to a software mixing program first then into vmix
thanks 1 user thanked Digitalson for this useful post.
PFBM on 11/25/2016(UTC)
PFBM
#13 Posted : Tuesday, November 15, 2016 1:06:37 PM(UTC)
PFBM
yes this works :
but... how gard can it be to implement inside vmix ????!!!
Amokka
#14 Posted : Wednesday, November 23, 2016 9:16:52 PM(UTC)
Amokka
Was thanked: 18 time(s) in 13 post(s)
+1 for VST
thanks 1 user thanked Amokka for this useful post.
Digitalson
#15 Posted : Friday, November 25, 2016 7:06:07 PM(UTC)
Digitalson
Groups: Guests
Well most productions use external stuff to mix audio ,mostly digital mixers...I use a software solution that I can automate with vmix via midi or program changes
PFBM
#16 Posted : Friday, November 25, 2016 8:09:31 PM(UTC)
PFBM
Audio on video is always the poor guy....
now with loudness rules bening more and more implemented...
having the possibility to have high quality finalization on the vmix system can lower costs and problems.
check this out :
http://www.fluxhome.com/...cts/plug_ins/level_magic
PFBM
Ittaidv
#17 Posted : Sunday, November 27, 2016 10:42:56 PM(UTC)
Ittaidv
Audio is indeed always the poor guy, sadly. I'm glad Martin implemented the multi channel sdi audio, but if I look at the requests I would like the most, they're almost all audio related. Also if I take a look at our desk: most outboard gear we use is audio related and takes a huge amount of desk space. Sometimes it's really difficult to create a workaround if the requirments of the job require something vmix can't do (yet).
I have may great plugins laying around, and a lot of dsp plugins on the soundcards. Many of them would be really useful and would cost me no extra money.
Since there is already midi support, it would be great if individual parameters of vst plugins could be linked to midi controllers, if this ever gets implemented.
Also important is to measure the vst cpu usage seperatly from the others. This way we can be sure the plugins don't destablise the system..
And to finish: it would be the bomb if we could use a typical setup with inserts, sends and returns. Perhaps hidden behind an 'advanced' button. So we can put it on a seperate screen. Would love to keep those bulky audio mixers home and just take a soundcard.
PFBM on 11/28/2016(UTC)
PFBM
#18 Posted : Monday, November 28, 2016 10:36:54 AM(UTC)
PFBM
so much simple and cost effective it would be to have real audio processing capabilities on vMix
not those it has very limited ... not eve gain reductio meter has on compressor....
my suggestion is to go full dynamic multhreading vst3 64 bits.
with automatic delay compensation.
Cheers,
PFBM
PFBM
#19 Posted : Wednesday, December 14, 2016 4:57:45 AM(UTC)
PFBM
Good Morning to all !!
Anyone from vMix care to comment on this issue ?
Cheers,
PFBM
