Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
Hy everyone!
Is there any way to receive an NDI Stream on a machine that is not running vMix? I've tried it on a Computer and I was able to receive the Video-Stream (or only the Audio if needed) via vMix.
Any possibility to open that stream f.e. on a web browser? That way it would be possible to stream the audio via network and receive it on a phone (iOs or Android) and therefore make it available for the guys behind the camera. Would be a nice, and in that case pretty convenient, intercom system.
Probably it's easy to accomplish and I am just missing something. Or it's simply not possible.
Any help appreciated.
Best regards
Fenki
Joined: 2/18/2014(UTC) Posts: 1,844 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Fenki, NewTek's Toolpack (for Windows, available via newtek.com/ndi) includes their "NDI Video Monitor" whick allows you to display an NDI source without vMix. To my knowledge there are no such apps for mobile devices out (yet). But I guess many will come. Se for example other ones from Sienna. I doubt NDI (whick uses relatively high bandwidth) is a good solution for intercom. (Looking forward to be proven wrong).
 1 user thanked richardgatarski for this useful post.
Thanks Richard!
I think that might be a possibility if you only send out the Audio Stream - with Video it's obiously too much used bandwith for the use as an intercom. However I think this might be worth trying and I'm looking forward to some apps for that to start testing... ;-)
NewTek NDI Connect Pro has a built in webserver that will allow any NDI stream on the network to be viewed in a web browser. It is video only, but does allow for multiple feeds to be viewed at once.
Kane Peterson NewTek
