wkrasley
#1 Posted : Wednesday, April 20, 2016 6:18:58 PM(UTC)
wkrasley
I downloaded and installed the pro edition, but don't need that yet. How can I change to the SD version?
#2 Posted : Wednesday, April 20, 2016 7:17:11 PM(UTC)
@ wkrasley
AFAIK, the Trial is full featured so you wont get the exact same limitations that the SD version has, but if you go to "Settings", you can set up your 'Output Size' and 'Output Aspect Ratio' to mimic what you would be limited to in the SD version.
Hope that helps some.
wkrasley
#3 Posted : Thursday, April 21, 2016 8:37:09 AM(UTC)
wkrasley
OK, thanks. I thought that I could just re-install and get the correct one, but it would not let me. I am trying to build a new system and do some testing and will not be using the HD version, but SD. I will go from here. Thanks!
Similar Topics
Trial edition installs (choose which version?) (General Discussion)
by MarkNF82 8/17/2019 12:16:53 AM(UTC)
