Hi All, New to vMix and have searched the forum without much success. I am trying to run vMix on a Windows 10, i7 processor with 16gb of ram.
I have loaded a powerpoint in one input and a video in the other input. The video runs fine and the powerpoint works fine. When I go to FULL SCREEN, which is a a second HDMI monitor, the powerpoint jerks when try to transition the slide to the next slide.
Take it off of FULL SCREEN the powerpoint works fine.
Any ideas?
Thanks...MG
Ok. Newbies issue. There was a transition in vMix that was default to each slide. As soon as I changed it to CUT it worked fine.
I do have one other question. Is there a way to advance the PPT to the next slide with a ENTER function instead of clicking on the >>|
Thanks...MG
 1 user thanked sinc747 for this useful post.
