matrixxdg
#1 Posted : Tuesday, April 12, 2016 3:19:28 PM(UTC)
matrixxdg
Hi All,
New to vMix and have searched the forum without much success. I am trying to run vMix on a Windows 10, i7 processor with 16gb of ram.
I have loaded a powerpoint in one input and a video in the other input. The video runs fine and the powerpoint works fine. When I go to FULL SCREEN, which is a a second HDMI monitor, the powerpoint jerks when try to transition the slide to the next slide.
Take it off of FULL SCREEN the powerpoint works fine.
Any ideas?
Thanks...MG
matrixxdg
#2 Posted : Tuesday, April 12, 2016 3:49:24 PM(UTC)
matrixxdg
Ok. Newbies issue. There was a transition in vMix that was default to each slide. As soon as I changed it to CUT it worked fine.
I do have one other question. Is there a way to advance the PPT to the next slide with a ENTER function instead of clicking on the >>|
Thanks...MG
sinc747
#3 Posted : Tuesday, April 12, 2016 3:54:24 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
I'm guessing you can use a Shortcut and any key you want.
http://www.vmix.com/help17/AddShortcut.html
- Tom
matrixxdg on 4/12/2016(UTC)
