Hi, I was searching a little bit but I didn't find the answer.
Is is possible to make a shortcut for scoreboard, for example. Pushung the up arrow key it would change home team score to +1, pushing down arrow key the same thing but + 1 for guests and so on.
I would like to change manually the score. For soccer it is not a problem, bit for basketball for example it is.
Thanks for your help
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
This feature will be available in v5. Specifically a new shortcut called "SetText" will be available and it can accept input such as +=1 or -=1 which will automatically add or subtract 1 from the current value.
Martin vMix
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
admin wrote:Hi,
Martin vMix Hi!!! First of all, sorry for my english... I want to know.. i'm testing v5 but i dont know if the shorcuts for the keyboard will be aviable on the final v5 or are now aviable on the beta version... Thanks and congratulations, vmix is amazing...
The shortcuts are in the v5 test version.
