Monitor Flashes On & Off When vMix 16 Plays A Video or DVD
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
This was reported from a customer this morning. Any ideas?
vMix 16 behaves just fine until I add a video file or DVD player as an input. Once added, the monitor begins to flicker, sometimes even before the source is played. Ironically, the video file that is included with Windows as a sample really goes berserk when you select audio as well. The flicker is more like an overall flash of the whole display. It blinks on and off as if someone is rapidly turning the power switch on and off. Once I close vMix, all returns to normal. The PC is fine running these same sources through other players. Like I said, rock solid.
Thank you for your input.
- Tom
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
sinc747 wrote:This was reported from a customer this morning. Any ideas?
- Tom
What version of Windows is your customer using?
That might be helpful
Windows 7/64
Other specs: i7-4790K with 16GB RAM ASRock Z97 Extreme4/3.1 LGA 1150 MB GeForce GTX 750 2GB (current driver) 750w PSU 240GB SSD main drive
- Tom
Hi Tom,
Here are my PC specs:
Windows 7/64bit
MOBO: Asus P6X58D-E CPU: Processor Intel Core i7 950 @ 3.07GHz, 3068 Mhz RAM: Patriot 8GB 1600MHz DDR3 X2 = 16GB GPU: Asus GT760, 2GB on board HD: 1TB 7600
I just tried 2 different video formats in vMix the first was a .mpg and the second was a .mp4 both at 1920 x 1080 resolution and both worked with no problems I also tried a DVD and again no problems playing that to.
What video format is your customer using and could there be something running in the background that could be causing the monitor to flash? and also what is the CPU usage when playing videos?
Len
Thanks for your reply. Everything works okay for me, too.
He is using the sample video, Wildlife.wmv, that comes with Windows 7.
Nothing is running in the background that I know of.
I'll check on CPU usage. Good idea.
- Tom
Joined: 1/13/2010(UTC) Posts: 5,329  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
Hi Tom,
I have seen this before with believe it or not a faulty HDMI cable or loose connection as the culprit. When there is lots of movement on screen a low HDMI signal can fail causing the screen to flicker which looks similar to what happens when unplugging/pluggin in the cable.
Martin vMix
admin wrote:Hi Tom,
Martin vMix Yes Martin you are right I have had this problem to with a HDMI cable.
But from Tom's original post, this appears to be an 'Internal' playback of a video from the hard drive and/or (I assume) a connection to the PC's DVD drive, no mention of an 'External' HDMI connection, so I suspect something is amiss.
The flashing occurs on the main monitor only when a video is being played in vMix with a DVD as the source or a video file on the SSD as a source.
The flashing does not occur when the is being played with Windows Media Center from either the DVD or a file on the SSD.
Main monitor is connected to the PC via HDMI.
- Tom
Hi Tom,
vMix uses the GPU much more heavily then say media center, VLC etc so it is still a good idea to check the cable and/or try a different monitor.
Martin vMix
admin wrote:Hi Tom,
Martin vMix Thanks Guys. Will do. Working with an out-of-town client, so things are proceeding slowly.
- Tom
