Showcase
HercegovinaLive Soccer showcase - Live streaming soccer game for local club - 1st division league
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
Livestraem soccer match today: NK Siroki Brijeg - NK Celik 6:00 PM TODAY, 20.03.2016., CET Live matchYoutube link
Live streaming soccer match, Bosnia & Herzegovina first league teams, Cup competition NK Siroki Brijeg - FK Radnik 5:30 PM TOMMOROW, 20.04.2016., CET Live from Siroki Brijeg, Pecara You can watch here: HercegovinaLiveor here: Official club pageWe will work with 2 cameras Sony NX30 and Sony NX5 (BMD Intensity Pro and MiniRec) enjoy
Live streaming soccer match, Bosnia & Herzegovina first league teams NK Siroki Brijeg - FK Borac 5:00 PM TODAY, 04.05.2016., CET Live from Siroki Brijeg, Pecara You can watch here: HercegovinaLiveor here: Official club pageWe will work with 2 cameras Sony NX30 and Sony PMW EX1 (BMD Intensity Pro and MiniRec) enjoy
I was streaming the first league (top league) match tonight. Using video delay, it was ok but only one thing was bad and that is when I play delayed video the audio was gone. I turn off on settings in video delay the option Mix audio on transition but nothing helped. THe played video delay thru all game was without sound. The auto mix audio was checked on few delayed video inputs but later I turn it off but nothing was changed. You can check how this was here: https://www.youtube.com/watch?v=owSYB425Ly4Any feedback and help is great p,s, great thing on my first using video delay is that CPU usage was aroung 45-50%.. Great! thx marko
My bad, I figure it out. I did not turn off automatic audio mix on my main camera that audio comes from. So turning off this on video delay was nothing without turning it off on main camera.
What a mistake, like an amateur
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
How does it work with save button? It saves clips in list so you can play it like some highlights? Is it able to see the clips and move the situations few second forward or backwards or it saves clips based on your feeling on click for 5, 10 secs?
I was wonderng on this because its hard to point on right moment to make replay clip when clicking on save button
thx marko
@ Siroki
Yes and no Marko, the saved video clips can be shortened and are the same as any other video where you can adjust the IN and OUT points. The disadvantage versus the "Instant Replay" feature is that you are restricted by the actual time frame you set-up, that is if you use a 10 second delay, you cannot see and/or reset to something that happened 15 seconds ago. Using the Video Delay feature for REPLAY is tricky and is all about proper timing and set-up. Saving clips is also a little tricky at first but the more you play and experiment with it the more you will understand how it works. I use shortcuts to trigger all my 'Replays', 'Stingers' and 'Saved clips'. Again, it's all about timing and then remembering to reset the time frame for the next time you need to go to the "Delay" (as you play with it and learn, you will see what I mean about "reset"). The nice thing is, you can even record (save) the delay without having to "go to air" with the "Video Delay", and then be able to play it back at a later time. It is quite effective when done properly, but does require considerable set-up and proper management and not nearly as full featured as the INSTANT REPLAY upgrade. Best advice I can give is to practice and test extensively to get your timing and set-up as 'goof proof' as possible.
IceStream wrote:@ Siroki
Ice Yes I understand. I can save clips, put it on preview for example and move the bar left or right but in that period of 5 or 10 seconds that I saved. Maybe its better then to go on 10sec clips because there is more space for editing or more space to pick the right timing. But the replay option for some situation with video delay is quite enough for my streaming. To return some situations, goals etc in slow motion and thats enough I will play with this some time and try to go with Instant Replay. Try to get it work. thx Marko
Today we were streaming Cup 1/16 finals I used replay again with UTC controler from elgarf for subs, yellow, red card, and goal scorer. It was ok with few small problems. Who is interested can se recorded game here: https://www.youtube.com/watch?v=s68qso7l5tU
Today we were streaming Cup 1/8 finals I used replay again with UTC controler from elgarf for subs, yellow, red card, and goal scorer. No problems with anything except small with audio Who is interested can se recorded game here: Analytics: 5,936 views :)
Very difficult conditions, poor road conditions, snow, rain and wind..4 hours driving.. inhospitable reception at the stadium ... but successfully implemented a live broadcast for 5 000 viewers... This weekend in two days 3 live streaming events (soccer, basketball, volleyball)..
Hi Siroki
do you use Tooway domestic or business broadband plans to stream? Or is it only the dish from Tooway? If so, can you tell me if you have problems, the bitrate you stream at ? I think upstream is limited to 6 Mbits, right ?
I never dared to try Tooway services. I usually use NewsSpotter on Eutelstat KaSat
Thanks Guillaume
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Same equipment, same satellite, different account ?
Yes and no... Not the same service and support, and certainly not the same billing!
DWAM wrote:Hi Siroki
Thanks Guillaume Hi, I use business package 25. That means 20/6 speed and 25 GB bandwith. I never had problems, I am satisfied with it maximum. On last stream I was out my beam for 20-30 kilometers, I had only 8,5-9db signal but everything was smooth, upload was 4,7 mbit. I can tell that only internet connection here where I live that I can trust is Tooway :) If you use Newspotter thats professional, I think you can get with it 20mbit upload but Newspotter is more expensive and I cannot afford that. Tooway is also Eutelsat KaSat I think. best regards
doggy wrote:Same equipment, same satellite, different account ? No, newspotter is more professional. And it's more expensive. I thing per 1GB you pay for about 50€. And in businesss25 of Tooway package you pay the whole month 65€, get speed 22/6 and 25GB bandwith.
Showcase
