Hardware Compatibility
Magewell USB capture dongle latency?
A friend is trying the Magewell USB 3.0 capture dongle. He reports about a half second of latency, which is a problem. Is that typical?
Moreover, is it typical of USB capture devices? I use an AVer Media HDMI capture card (PCIe) which doesn't have as much latency. A couple of frame is what I typically see.
Thanks,
Michael
Joined: 3/9/2016(UTC) Posts: 33  Location: Cotswolds, UK
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Half a second is definitely not normal, couple of frames at most, similar to capture cards.
May need to check device manager to make sure it is being detected as USB 3
