Hardware Compatibility
Configuring Black Magic Mini Recorder and Audio
Joined: 11/14/2015(UTC) Posts: 55 Location: Sacramento, CA
Thanks: 8 times Was thanked: 4 time(s) in 3 post(s)
Hello, I've been trying to configure the audio to my BM Mini Recorder with my USB Input Mixer (Behringer), but I don't have that option in Vmix to add the correct sound input. I'm able to add the audio in my Magewell 4 port SDI for each of the inputs but not on the BM. Is there a secret to this? Process Add Input > Camera > camera drop down > DeckLink Mini Recorder 1 Audio Input is greyed out at "Default" And yes, I've tried the other BM Selections to my camera and the only one that works is the DeckLink Mini Recorder 1 selection. The last snapshot shows my configuration for the Magewell port with the Audio. mavrick816 attached the following image(s):  BM Card.png (64kb) downloaded 8 time(s). Bm2.JPG (67kb) downloaded 9 time(s). Mag.JPG (69kb) downloaded 12 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
So you are bringing in the Video through the Magewell card and audio separately via an audio interface? Can you confirm the audio is able to be brought in to vMix with an Audio Input on its own? I was having almost the same issue with my Scarlett USB interface just the other day.
Yes, I was able to bring in the Audio Input by itself. It shows up as Microphone (USB Audio CODEC) from my Berhinger mixer. I can enable the sound manually when I switch to the BM Camera, but that would suck. I would rather do the switching with Audio and Sound together. The Magewell card SDI Input is configured with the "Microphone (USB Audio CODEC)" as the incoming "Audio Device" Cpilcher wrote:So you are bringing in the Video through the Magewell card and audio separately via an audio interface? Can you confirm the audio is able to be brought in to vMix with an Audio Input on its own? I was having almost the same issue with my Scarlett USB interface just the other day.
Ok, I'm sure someone will be on here soon to help you out. I don't have a Mini Recorder to test and if the mixer audio is able to be selected independently I would assume it should be able to be selected as the audio source for the Mini Recorder feed...
With my Mini Recorders (PCI-E & Thunderbolt) I'm able to select "DeckLink Video Capture" and can select any audio device for this. Working perfectly.
I selected "DeckLink Mini Recorder 1", that works with video but not the correct audio. I tried "DeckLink Video Capture" and my video does not come up for any resolution or configuration, but I do have the audio selection ovinas wrote:With my Mini Recorders (PCI-E & Thunderbolt) I'm able to select "DeckLink Video Capture" and can select any audio device for this. Working perfectly.
@ mavrick816
I'm not familiar with your hardware and its options and/or conflicts but if your audio and video inputs are separate but you want to 'play' them simultaneously I would set up that up with the "Triggers" feature, such that every time the camera is selected and deselected the Audio Input is turned on and off. Perhaps not the desired solution but will give the desired result.
Hey Ice, this is Mav.... LOL. Ya so I laready created a trigger as a work around with duration of 999999, its a messy config, but it works. Does anyone know what the "Duration" is? is it in millisec or sec or mins? Would rather configure the direct video and audio source. IceStream wrote:@ mavrick816
Duration is in milliseconds. 1000ms = 1 second
Rank:: Advanced Member
This behaviour occurs only if you select the Ultrastudio Mini Recorder as the input source. If you choose the Decklink Video Capture you have the full range of Audio options to choose from.
When I choose the video capture option, I don't get any video feeds in any resolution configuration :( ask wrote:This behaviour occurs only if you select the Ultrastudio Mini Recorder as the input source. If you choose the Decklink Video Capture you have the full range of Audio options to choose from.
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4739 time(s) in 1626 post(s)
The audio dropdown list for Camera is only designed to be used with capture cards that provide audio separately, such as the Magewell. This is why when selecting the Mini Recorder dropdown option, Default is only available as the audio is automatically handled from either HDMI, SDI or Analog.
Instead, to have a particular audio source automatically mixed alongside the video is quite easy:
1. Add the audio separately as an audio input 2. From the Input Settings of the camera add it under the MultiView tab in any of the 5 dropdown boxes. 3. From the Input Settings of the audio input make sure "automatically mix audio" is ticked.
Martin vMix
BINGO!! Thanks Martin! It worked! But as a note, I used the BM Decklink Mini Recorder with "uhum another product :)" the Wirec*** App, I was able to bring in Video and Audio with the Declink. During a broadcast last September, I used an SDI input from a broadcast network feed that had both audio and video and it worked. Oh well, it works now with the BM card and if I need to feed both audio and video, I'll use the Magewell ports. thanks again Martin!! admin wrote:Hi,
Martin vMix
