phab
#1 Posted : Thursday, February 18, 2016 10:57:52 AM(UTC)
phab
Could you connect the HDMI output of the camera or DSLR on this network converter?
http://www.cable-hdmi.eu/hdmi-v...t-vers-hmdi-over-ip.html
Best regard
Phab
pm
#2 Posted : Thursday, February 18, 2016 12:02:33 PM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hi
I have this devices in use.
Yes, you can connect your camera HDMI output to this device. They are using IP to transmit the signal, but it's a proprietary protocol. The protocol is not NDI! So you need the receiver on the other side to decode the stream (and convert it to HDMI again).
It's not possible to receive the stream directly in vMix.
You need a dedicated network, you cannot use an existing network infrastructure. If you want to use your existing network infrastructure you have to look for a HDbitT device like this: http://www.lenkeng.net/Index/detail/id/130.
The delay is about ~1000ms. Picture quality is not perfect, but quiet good (they use MJPEG compression).
Some more inside information about these devices:
https://blog.danman.eu/r...g-hdmi-over-ip-extender/
I use them to transmit vMix output HDMI Signal over longer distances, where delay is not important (for screens in other rooms for example).
Patrick
phab
#3 Posted: : Friday, February 19, 2016 4:11:47 AM(UTC)
phab
Patrick thank you for that clarification, I understand better the NDI.
Waiting to see the industry we provide converters NDI ...
Regard,
Phab
bartek
#4 Posted : Friday, February 19, 2016 8:07:23 AM(UTC)
bartek
Propably You can write some aplication to convert ip stream to NDI stream, read this article:
http://blog.danman.eu/re...g-hdmi-over-ip-extender/
phab
#5 Posted : Tuesday, February 23, 2016 4:30:43 AM(UTC)
phab
Thank bartek,
The advantage of boxes with firmware (programming) updates are possible for Newtek NDI may change their SDK.
phab
