jdauthre
#1 Posted : Tuesday, July 31, 2012 7:40:32 AM(UTC)
jdauthre
Hi
Does anyone know if there is a way of opening vMix with an already created preset loaded, maybe a command line switch ?
Thanks in advance
#2 Posted : Tuesday, July 31, 2012 8:18:36 AM(UTC)
Was thanked: 4729 time(s) in 1621 post(s)
The command line is:
vmix2012.exe "filename.vm7"
melody
#3 Posted : Tuesday, July 31, 2012 9:05:28 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
talking about presets, would be great if user could select the version of vMix (x86 or x64) to open the preset file.
regards,
melody
www.espiritosanto.cc
jdauthre
#4 Posted : Tuesday, July 31, 2012 9:12:21 AM(UTC)
jdauthre
Thanks, that works, although need to ensure the preset file is in the program folder
Regards
jdauthre
#5 Posted : Tuesday, July 31, 2012 9:44:03 AM(UTC)
The full path can be specified as well, for example:
vmix2012.exe "c:\mypresets\thepreset.vm7"
DanielMuhlig
#6 Posted : Wednesday, August 1, 2012 5:04:44 AM(UTC)
DanielMuhlig
...or just doubleclick the preset file.
