Hi Does anyone know if there is a way of opening vMix with an already created preset loaded, maybe a command line switch ? Thanks in advance
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
The command line is:
vmix2012.exe "filename.vm7"
Rank: Guest
Groups: Guests
hi martin, talking about presets, would be great if user could select the version of vMix (x86 or x64) to open the preset file. regards, melody www.espiritosanto.cc
admin wrote:The command line is:
vmix2012.exe "filename.vm7" Thanks, that works, although need to ensure the preset file is in the program folder Regards jdauthre
The full path can be specified as well, for example:
vmix2012.exe "c:\mypresets\thepreset.vm7"
admin wrote:The full path can be specified as well, for example:
vmix2012.exe "c:\mypresets\thepreset.vm7" ...or just doubleclick the preset file.
