Instant Replay
ShuttlePRO V2 Button Mapping for Instant Replay
Thanks: 23 times Was thanked: 13 time(s) in 10 post(s)
Have any of you got your ShuttlePRO button layouts exactly the way you want them to contorl InstantReplay? I once saw a great video on youtube where the guy explained what he had assigned to each button, but I can't seen to find it. I'm looking for a best practices example, but I'm also interested in what everyone has found that works well/doesn't work well.
Thanks!
 1 user thanked tnorrell for this useful post.
@ tnorrell
Yes, I have mapped my ShuttlePRO with a profile that worked well for me. If I remember correctly, I allocated existing 'Shortcut' keys to the buttons within the Shuttle's settings window and saved it as a new profile. Since the beta testing has expired, I have not used the Shuttle but even with all those buttons, I remember thinking that there were still not enough to do everything I wanted, so think carefully about your workflow and what each button should do for you. (When I get back to the office next week, I'll see if I can post a screenshot of my layout)
As promised:  The vMix graphic, unfortunately, does not list the full function of each button because the command description is too long, but I can say that each one is different. This is how it looks in vMix Shortcuts window:  The "MoveSelected" In/Out points are each + or - 15 frames respectfully. Hope that helps some. Ice
Thank you for your follow up. I appreciate the template screen shots. If you wouldn't mind...how many cameras are you recording for your replay?
@ tnorrell
During the beta testing, the most I ran at one time was three, but more often than not, I only used one or two the majority of the time.
Instant Replay
