tnorrell
#1 Posted : Saturday, February 13, 2016 3:14:33 AM(UTC)
tnorrell
Was thanked: 13 time(s) in 10 post(s)
Have any of you got your ShuttlePRO button layouts exactly the way you want them to contorl InstantReplay? I once saw a great video on youtube where the guy explained what he had assigned to each button, but I can't seen to find it. I'm looking for a best practices example, but I'm also interested in what everyone has found that works well/doesn't work well.
Thanks!
thanks 1 user thanked tnorrell for this useful post.
sinc747 on 2/13/2016(UTC)
#2 Posted : Saturday, February 13, 2016 8:54:47 AM(UTC)
@ tnorrell
Yes, I have mapped my ShuttlePRO with a profile that worked well for me.
If I remember correctly, I allocated existing 'Shortcut' keys to the buttons within the Shuttle's settings window and saved it as a new profile.
Since the beta testing has expired, I have not used the Shuttle but even with all those buttons, I remember thinking that there were still not enough to do everything I wanted, so think carefully about your workflow and what each button should do for you.
(When I get back to the office next week, I'll see if I can post a screenshot of my layout)
#3 Posted : Monday, February 15, 2016 12:40:06 PM(UTC)
As promised:
The vMix graphic, unfortunately, does not list the full function of each button because the command description is too long, but I can say that each one is different.
This is how it looks in vMix Shortcuts window:
The "MoveSelected" In/Out points are each + or - 15 frames respectfully.
Hope that helps some.
Squier on 2/15/2016(UTC)
tnorrell
#4 Posted : Tuesday, February 16, 2016 6:43:35 PM(UTC)
tnorrell
Thank you for your follow up. I appreciate the template screen shots. If you wouldn't mind...how many cameras are you recording for your replay?
#5 Posted : Tuesday, February 16, 2016 8:21:41 PM(UTC)
@ tnorrell
During the beta testing, the most I ran at one time was three, but more often than not, I only used one or two the majority of the time.
Guest (4)
