tgdzapa1
#1 Posted : Sunday, February 7, 2016 9:11:05 AM(UTC)
tgdzapa1
Hi vMix fans
From my main PC goes a lan cable do my second pc. On my second pc desktop capture client gives me
a perfect overview. So good so far.
But on my second pc I can use the shortcuts same way as on my main PC. :-(
Have anyone a good idea or a good software? [img][/img]
Thansk for reply.
Patrick
tgdzapa1 attached the following image(s):
#2 Posted : Sunday, February 7, 2016 11:47:34 AM(UTC)
@ tgdzapa1
Not sure I understand...
The web interface should work fine with the mouse and/or a touch pad or touch screen.
The "Shortcuts" 'F5' and 'F6' that you assigned are linked to the keys on your main PC, not the keys on your second PC, the web interface just creates clickable 'buttons' that reference the assigned shortcut key.
The only way to use the keys on your second PC would be to allow remote access to your main PC, much like a computer support person might do over the internet (a program like "TeamViewer" or "SplashTop" will allow you to do that, but that kind of over-complicates your set-up).
I hope I have understood you correctly and that this helps to clarify.
tgdzapa1
#3 Posted : Wednesday, February 10, 2016 5:07:53 AM(UTC)
tgdzapa1
Thanks Ice for reply.
Pity. Would be perfect on the second screen if instead of a mouse clicks the operator can take
the shortcuts from main pc. No change? html script ?
the app https://itunes.apple.com...surface/id978932322?mt=8
is maby a solution? Or it's only a ipad touch app?
Lennart
#4 Posted : Thursday, February 11, 2016 7:11:24 PM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
It's iPad only for now, but they're working on an iPhone version. It works well, I've used it a couple of times.
