Web Controller with shortcuts
Joined: 1/21/2014(UTC) Posts: 83 Location: sportwebtv.be
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Hi vMix fans From my main PC goes a lan cable do my second pc. On my second pc desktop capture client gives me a perfect overview. So good so far. But on my second pc I can use the shortcuts same way as on my main PC. :-( Have anyone a good idea or a good software? [img][/img] Thansk for reply. Patrick tgdzapa1 attached the following image(s):  Unbenannt.PNG (26kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
@ tgdzapa1
Not sure I understand... The web interface should work fine with the mouse and/or a touch pad or touch screen. The "Shortcuts" 'F5' and 'F6' that you assigned are linked to the keys on your main PC, not the keys on your second PC, the web interface just creates clickable 'buttons' that reference the assigned shortcut key. The only way to use the keys on your second PC would be to allow remote access to your main PC, much like a computer support person might do over the internet (a program like "TeamViewer" or "SplashTop" will allow you to do that, but that kind of over-complicates your set-up).
I hope I have understood you correctly and that this helps to clarify.
Thanks Ice for reply. Pity. Would be perfect on the second screen if instead of a mouse clicks the operator can take the shortcuts from main pc. No change? html script ? the app https://itunes.apple.com...surface/id978932322?mt=8is maby a solution? Or it's only a ipad touch app? ....
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
It's iPad only for now, but they're working on an iPhone version. It works well, I've used it a couple of times.
