2 Pages<12
fortsquarechurch
#21 Posted : Sunday, February 7, 2016 9:01:59 PM(UTC)
fortsquarechurch
Hello kjones9999,
I've am doing some research on computers and found a Dell.
Its the same model I use for my home server, it's a good model because you can easily customize the model.
Is it possible to use capture cards connected to PCI, if yes, how do I install it and configure it to vMix?
Zach
sinc747
#22 Posted : Monday, February 8, 2016 2:56:16 AM(UTC)
sinc747
Dells don't like Blackmagic cards, or maybe its the other way around.
AJA, Magewell, Yuan, etc. seem to do OK. Check the vMix Supported Hardware page for a list of what is known to work with vMix: http://www.vmix.com/soft.../supported-hardware.aspx
- Tom
2 Pages<12
