jpdesroc
#1 Posted : Thursday, January 28, 2016 11:58:22 AM(UTC)
jpdesroc
I just bought 2 Logitech 920c Pro USB webcams to use with Vmix.
I can easily add both of them into Vmix.
But When I do so each of these webcam don't show any audio available
inside their own input windows. To get audio from each of these Webcam
I need to add separate 'audio' inputs from Vmix to get the sound..
Is-it normal ? These webcams have their own stereo microphones..
Thanks for you help.
#2 Posted : Thursday, January 28, 2016 12:09:04 PM(UTC)
Was thanked: 509 time(s) in 478 post(s)
@ jpdesroc
Yes, typically webcams require a separate audio input.
jpdesroc
#3 Posted : Thursday, January 28, 2016 12:16:35 PM(UTC)
jpdesroc
Thank you for your fast reply .
jhebbel
#4 Posted : Thursday, January 28, 2016 7:04:57 PM(UTC)
jhebbel
IceStream wrote:
@ jpdesroc
What? No? My 920c audio inputs show up in the audio source when selecting the camera inputs.
jpdesroc
#5 Posted : Thursday, January 28, 2016 7:12:08 PM(UTC)
jpdesroc
Hmmmm...
I use Vmix ver 14. What version do you use that shows audio
in the 920c webcam input window ?
#6 Posted : Thursday, January 28, 2016 8:23:20 PM(UTC)
@ jhebbel
Perhaps a slight clarification is in order...
vMix does not typically recognize "Built in Audio" as the source for audio on webcams when adding them as "Inputs", you have to choose your "Audio Device", of which the webcam mic is often among your choices, or you can add it as an independent "Audio Input", essentially, with Webcams 'Audio' and 'Video' tend to be handled separately.
