Logitech 920c Pro USB webcams with audio needed to be added separately..
I just bought 2 Logitech 920c Pro USB webcams to use with Vmix. I can easily add both of them into Vmix. But When I do so each of these webcam don't show any audio available inside their own input windows. To get audio from each of these Webcam I need to add separate 'audio' inputs from Vmix to get the sound.. Is-it normal ? These webcams have their own stereo microphones.. Thanks for you help.
Joined: 3/7/2012(UTC) Posts: 2,682  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ jpdesroc
Yes, typically webcams require a separate audio input.
Thank you for your fast reply .
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
IceStream wrote:@ jpdesroc
Ice What? No? My 920c audio inputs show up in the audio source when selecting the camera inputs.
Hmmmm... I use Vmix ver 14. What version do you use that shows audio in the 920c webcam input window ?
@ jhebbel
Perhaps a slight clarification is in order... vMix does not typically recognize "Built in Audio" as the source for audio on webcams when adding them as "Inputs", you have to choose your "Audio Device", of which the webcam mic is often among your choices, or you can add it as an independent "Audio Input", essentially, with Webcams 'Audio' and 'Video' tend to be handled separately.
