mitchstein443
#1 Posted : Sunday, January 10, 2016 9:22:55 PM(UTC)
mitchstein443
vmix error
D3DStartup.D3D_NEW_EX
D3DERR_INVALIDCALL: Invalid call (-2005530516)
system has directx installed, videocard is compatible, this is a dual boot computer win7 and win10 under win7 runs perfectly
I'm confused here is dxdiags results under win10:
Name: Intel(R) 82945G Express Chipset Family (microsoft
Manufacturer: Intel
Chip Type: Intel(R) 82945G Express Chipset Family
DAC Type: Internal
Device Type: Full Display Device
Current Display Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor: Generic PnP Monitor
DirectX Features
DirectDraw Acceleration: Enabled
Direct3D Acceleration: Enabled
AGP Texture Acceleration: Enabled
notes
no problems found.
what am i missing?
Ed Tech
#2 Posted : Monday, January 11, 2016 9:49:29 AM(UTC)
Ed Tech
DirectX 10 is the recommended minimum for a graphics card.
This per the vMix website. Home - Software - System Requirements.
Hope there's another, better answer.
mitchstein443
#3 Posted : Wednesday, January 27, 2016 2:52:26 PM(UTC)
mitchstein443
I thought it was directx 9.. is this because I'm using vmix 16 instead of 15 when I started out with this? BUT I believe directx 10 ships with win 10 64? I am cofused because this video card is working just fine on the windows 7 enterperise partition but not when booted to windows 10, hardware doesn't change just OS..
jhebbel
#4 Posted : Wednesday, January 27, 2016 4:32:03 PM(UTC)
jhebbel
Make sure your GPU drivers are up to date
#5 Posted : Thursday, January 28, 2016 5:09:23 AM(UTC)
Was thanked: 4665 time(s) in 1607 post(s)
The 945G is an old integrated graphics from Intel and is not supported by vMix for many years.
(945G was launched in 2005)
Installing any mid range graphics card from the past few years will work well with vMix.
mitchstein443
#6 Posted : Thursday, January 28, 2016 10:55:31 PM(UTC)
mitchstein443
Yep, so I found out.. this was our old video capture to dvd/wmv pc, someone musta removed the videocard that was in it.. However, vmix is working on it in win7 and not win10 must be the driver version or something and I see no newer drivers for win 10. AND it's just so slow..
Thought it would be a good machine to dedicate to a live broadcasting mix machine.. I got it all working now in an oracle virtualbox on my i7 gonna spend a few days testing before going live with it..
