Mathijs
#1 Posted : Tuesday, January 26, 2016 9:13:06 PM(UTC)
Mathijs
Was thanked: 81 time(s) in 72 post(s)
I would like to see api commands for the virtual set camera controls.
#2 Posted : Tuesday, January 26, 2016 11:52:33 PM(UTC)
Was thanked: 506 time(s) in 475 post(s)
@ Mathijs
What is it you would like to do that you can't do now?
Mathijs
#3 Posted : Wednesday, January 27, 2016 9:02:25 PM(UTC)
Mathijs
I would like to have commands to select the 4 camera positions within the API, so I can make macro's and script things.
I have been searching the api commands for this, but did not manage to find them. If they are there already, please show me ;)
#4 Posted : Thursday, January 28, 2016 10:44:56 AM(UTC)
@ Mathijs
I am not exactly clear on the API semantics side of things, but to the best of my knowledge, the "Shortcut" to transition from one camera view to another within a 'Virtual Set' is to use the appropriate "Transition" shortcut (Fade/Merge/Zoom) to the desired shot (CloseUp/Mediu/Full).
http://forums.vmix.com/d....aspx?g=posts&t=3735
Hope that helps some...
Mathijs
#5 Posted : Thursday, January 28, 2016 5:40:43 PM(UTC)
Mathijs
Thank you, almost can't wait to try this. ;)
I will let you know if this gives me the desired result.
Mathijs
#6 Posted : Friday, January 29, 2016 11:26:49 AM(UTC)
Mathijs
Working! Thanks a lot!
