I would like to see api commands for the virtual set camera controls.
@ Mathijs
What is it you would like to do that you can't do now?
I would like to have commands to select the 4 camera positions within the API, so I can make macro's and script things. I have been searching the api commands for this, but did not manage to find them. If they are there already, please show me ;)
@ Mathijs I am not exactly clear on the API semantics side of things, but to the best of my knowledge, the "Shortcut" to transition from one camera view to another within a 'Virtual Set' is to use the appropriate "Transition" shortcut (Fade/Merge/Zoom) to the desired shot (CloseUp/Mediu/Full). http://forums.vmix.com/d....aspx?g=posts&t=3735Hope that helps some... Ice
Thank you, almost can't wait to try this. ;) I will let you know if this gives me the desired result.
