Hi! As I can choose one or the other actions:
1. Take transition and immediately playing back 2. Take transition and expect command to play
I want to establish it once and to apply to any video clips at will.
Thanks.
@ Alex_Lap
Please explain further... It is unclear what you want.
Sometimes I want press button "Fade" and my video start playng during transition. Sometimes I want press button "Fade" and my video only appear in Program Monitor, but not playing.
How can I define both shortcuts?
I know about personal setting for each Inputs, but can I make "Master Choose"?
@ Alex_Lap
AFAIK, the default setting for 'Video' Inputs is for them to "Automatically Play with Transition" (cog wheel:General Settings) and it is "either - or" not switchable with a 'Shortcut' but rather 'mannually'. To accomplish what you suggest with 'Shortcuts', I would be inclined to set up my videos to not play when sent to "Program" screen (un-tick afore mentioned settings box) when inputting them into vMix. Next, set-up two different 'Shortcuts', one to "Play / Active Input" (to play paused videos when wanted) and one to "Quick Play / Preview" (to play a video as soon as it transitions from "Preview" to "Program"). This will require you to "Preview" each video input first (send to "Preview" screen) and to set-up your "QuickPlay" transition to your desired default in order to work properly. Please note that the "QuickPlay" feature/button WILL play the video (Override the setting so to speak) as that is what you are asking it to do.
Hope that helps some.
