KCPro
#1 Posted : Wednesday, December 30, 2015 9:10:51 PM(UTC)
KCPro
I currently have a 500GB SSD for my operating system and vMix, I need more space to record ISO.
Can I add another SSD and make that the one that the recordings go to?
If I do it that way, so I lose any speed?
Any downside to doing it that way?
Or should I just start from scratch and get a 1TB SSD?
Thank you for any help.
SportsNetUSA.net
#2 Posted : Wednesday, December 30, 2015 9:59:27 PM(UTC)
SportsNetUSA.net
Other than the cost of buying it, I can't think of a downside to adding another SSD to your system. Unless your system has an under-powered power supply, there shouldn't be any negative issues. If you have vMix Pro or 4X and are going to use Instant Replay you should have another drive. I have one desktop system (vMix & Wirecast) running 3 drives, a RAID SSD pair for the OS and a hard drive dedicated to storage.
#3 Posted : Wednesday, December 30, 2015 10:23:38 PM(UTC)
Was thanked: 509 time(s) in 478 post(s)
@ KCPro
I agree with SportsNetUSA.net. There should be no issue with running multiple drives on a desktop computer provided it has the capacity, in fact, I would highly recommend it. Even an appropriately connected external drive on a laptop can be beneficial.
ask
#4 Posted : Thursday, December 31, 2015 12:07:43 AM(UTC)
ask
The recommendations you will find on this forum is to run seperate SSD's per ISO. It is possible to record them with less however. The vMix Go is spec'd with 4 hotswap SSD bays, and Martin has suggested that he recommends Crucial Drives. I have been using multiple SSD's (Sandisk and Samsung) without issue for the last three years.
mjgraves on 12/31/2015(UTC)
mjgraves
#5 Posted : Thursday, December 31, 2015 11:29:29 AM(UTC)
mjgraves
SSDs use so little power that the power supply should never be a factor. If adding an SSD pushes it over the edge then your system would likely have been unstable already.
