Audio output while recording
Joined: 12/23/2015(UTC) Posts: 1 Location: Walla Walla, WA
All, I have a situation where I was hopeful we can modify the audio output from vmix while recording a session. Here is what we have: We have two rooms: Room A is the coaches room, inside this room is the computer/workstation, a microphone, and a one way communication to room B to coach the people in room B. In room B we have a microphone and a USB webcam. In this room we have two people, one of the people is wearing a headset listening to coaching from room A. Using Vmix and the two microphones, we are capturing the video from room B, and the audio from room A and B. Vmix works perfectly, the only problem is the coach in room A is requesting - "Can you turn this microphone off so I don't hear myself, the echo is very distracting" The coach is wearing a set of headphones to listen to the audio from room B, but also hears the audio in room A. I tinkered in vmix and found the mute button to mute the audio from room B but that mutes the audio from the recording as well, which we need to capture, so that won't work. Is there a way to mute one audio input from monitoring but not mute it from the recording?
