Instant Replay
In Transition with Fade-> Stinger > Replay sequence -> Stinger -> Out Transition Fade
Joined: 1/21/2014(UTC) Posts: 82 Location: sportwebtv.be
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Hi How can I set e stinger in and out transition with fade in and fade out? I got always a cut instead of fade and this is not the broadcast standard. Thanks for help. BR Patrick tgdzapa1 attached the following image(s):  replay.PNG (21kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
If I recall correctly, you can change the Stinger options by clicking the overlay button in the bottom right corner, selecting the overlay you wish to modify (Stinger1), and change the transition defaults there.
I don't have replay capability so can't verify this for you.
If it works for you, then I was glad to help!
 1 user thanked tgdzapa1 for this useful post.
Instant Replay
