tgdzapa1
#1 Posted : Wednesday, December 16, 2015 10:20:17 AM(UTC)
tgdzapa1
Hi
How can I set e stinger in and out transition with fade in and fade out?
I got always a cut instead of fade and this is not the broadcast standard.
Thanks for help.
BR
Patrick
tgdzapa1 attached the following image(s):
madness
#2 Posted : Wednesday, December 16, 2015 10:52:37 AM(UTC)
madness
If I recall correctly, you can change the Stinger options by clicking the overlay button in the bottom right corner, selecting the overlay you wish to modify (Stinger1), and change the transition defaults there.
I don't have replay capability so can't verify this for you.
tgdzapa1
#3 Posted : Wednesday, December 16, 2015 11:39:16 AM(UTC)
tgdzapa1
G R E A T
madness
#4 Posted : Thursday, December 17, 2015 3:11:50 PM(UTC)
madness
If it works for you, then I was glad to help!
tgdzapa1
#5 Posted : Monday, December 21, 2015 9:28:48 AM(UTC)
tgdzapa1
It works yes. Thank you
thanks 1 user thanked tgdzapa1 for this useful post.
madness on 12/22/2015(UTC)
