Hi everybody!
In the list of vMix supported equipment there is software based capture card YUAN SC 510 N4 HDMI with 4 channel of capture. But YUAN has also SC580 N4 HDMI - which uses hardware based encoding. Does vMix support this card? Have you got some positive useful experience?
Regards, Roman
BisonTV wrote:Hi everybody!
Regards, Roman У них на сайте написано, что поддерживает vMix эти карты. Или ты уже использовал ее? They wrote on his website that supports vMix these cards.
Does anyone know if there is an advantage while using vMix with the SC580 vs the SC510 or SC542 cards? (given the hardware encoding capability - does vMix leverage this?)
mattd_br wrote:Does anyone know if there is an advantage while using vMix with the SC580 vs the SC510 or SC542 cards? (given the hardware encoding capability - does vMix leverage this?) sc510 doesn't work with x99 motherboards. I would not buy it unless you don't plan to keep the card while upgrading your computer in the future. It looks like there is no workaround for this.
