BisonTV
#1 Posted : Thursday, October 30, 2014 9:57:19 AM(UTC)
BisonTV
Hi everybody!
In the list of vMix supported equipment there is software based capture card YUAN SC 510 N4 HDMI with 4 channel of capture.
But YUAN has also SC580 N4 HDMI - which uses hardware based encoding.
Does vMix support this card?
Have you got some positive useful experience?
Regards, Roman
fey13
#2 Posted : Saturday, January 17, 2015 5:53:06 PM(UTC)
fey13
BisonTV wrote:
Hi everybody!
Regards, Roman
У них на сайте написано, что поддерживает vMix эти карты.
Или ты уже использовал ее?
They wrote on his website that supports vMix these cards.
mattd_br
#3 Posted : Wednesday, December 2, 2015 10:27:02 AM(UTC)
mattd_br
Does anyone know if there is an advantage while using vMix with the SC580 vs the SC510 or SC542 cards? (given the hardware encoding capability - does vMix leverage this?)
Ittaidv
#4 Posted : Tuesday, December 15, 2015 1:53:56 PM(UTC)
Ittaidv
sc510 doesn't work with x99 motherboards. I would not buy it unless you don't plan to keep the card while upgrading your computer in the future. It looks like there is no workaround for this.
