ON.tv Channels
#1 Posted : Tuesday, December 15, 2015 9:33:39 AM(UTC)
ON.tv Channels
Tried installing both via your update method and straight install and both times I see the attached message
ON.tv Channels attached the following image(s):
vmix update error.jpg (56kb) downloaded 0 time(s).
Len56
#2 Posted : Tuesday, December 15, 2015 10:32:00 AM(UTC)
Len56
I just downloaded 16.0.0.111 and it installed with no problems, I am using windows 7 what are you using?
Try a complete un-install from your control panel then download vMix again, then re-install again and see if you still have the same problem.
ON.tv Channels
#3 Posted : Tuesday, December 15, 2015 1:30:42 PM(UTC)
ON.tv Channels
Windows V10 PRO - 1511 (build 10586.29)
