Problem installing new update 16.0.0.111
Thanks: 107 times Was thanked: 2 time(s) in 2 post(s)
Martin Tried installing both via your update method and straight install and both times I see the attached message ON.tv Channels attached the following image(s):  vmix update error.jpg (56kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
I just downloaded 16.0.0.111 and it installed with no problems, I am using windows 7 what are you using?
Try a complete un-install from your control panel then download vMix again, then re-install again and see if you still have the same problem.
Len56 wrote:I just downloaded 16.0.0.111 and it installed with no problems, I am using windows 7 what are you using?
Try a complete un-install from your control panel then download vMix again, then re-install again and see if you still have the same problem. Windows V10 PRO - 1511 (build 10586.29)
