calamityjane
#1 Posted : Friday, December 11, 2015 5:15:12 PM(UTC)
calamityjane
Hi
The BLAB screen can be captured (Desktop Capture) as an input, I am wondering how can I capture the audio from the BLAB conversations and send them to my output.
I would like to employ BLAB for online discussions during the intermissions of our hockey broadcasts.
Whit
ask
#2 Posted : Friday, December 11, 2015 5:28:48 PM(UTC)
ask
Have you tried routing the audio using a virtual cable?
calamityjane on 12/11/2015(UTC)
calamityjane
#3 Posted : Friday, December 11, 2015 5:47:08 PM(UTC)
calamityjane
I do have Virtual Cable installed. I really don't have my head around this whole mix minus thing (Skype) but will toy with it now that you mention it is a possibility. Not ure about configuration. BLAB out via Virtual Cable 1 and use this as an input ?
Whit
ask
#4 Posted : Friday, December 11, 2015 7:36:53 PM(UTC)
ask
Yep. I haven't looked at Blab but I suspect it is like other apps, so that's what I would try. If Blab allows you to define the output source send it off to Virtual connection
w14
#5 Posted : Saturday, December 12, 2015 4:41:48 AM(UTC)
w14
Have a look at the diagram that Keith posted here: http://forums.vmix.com/d...ts&m=21389#post21389
He is running Skype on the same machine as vMix, but it's not too different if you have Skype on a separate machine.
If you need help getting your head around mix minus in principle, Vance Willis' video is a great start:
thanks 1 user thanked w14 for this useful post.
calamityjane on 12/12/2015(UTC)
calamityjane
#6 Posted : Saturday, December 12, 2015 9:24:03 AM(UTC)
calamityjane
That is good stuff, very helpful. I was having difficulty with Skype as well.
Will peruse in detail tomorrow and give it a try. Thanks so much.
Whit
mjgraves
#7 Posted : Saturday, December 12, 2015 3:28:17 PM(UTC)
mjgraves
Being WebRTC-based BLAB doesn't allow you to select the audio output device.
That means that for now you must use something like Virtual Audio Cable, VB-Cable or VoiceMeeter to provide the necessary audio signal routing.
calamityjane
#8 Posted : Sunday, December 13, 2015 3:10:47 PM(UTC)
calamityjane
On first attempt I did get the audio from BLAB recorded in vMix. Unfortunately it had an echo. There must be something more to it than my simplsitic approach. Aslo thinking if I want to be part of the conversation ......
All I did was assign the defualt playback device on my computer to be Line1, and then added Line1 as an input to vMix.
Any pointers for this non audiophile?
whit
w14
#9 Posted : Monday, December 14, 2015 2:31:55 PM(UTC)
w14
That would create echo all right. vMix uses the default playback device as its master output and its headphone output by default. So you're feeding that back in as an input and thus the echo.
How about this - go to vMix -> Settings -> Audio Outputs and change the settings for Master Output and Headphones. Maybe you could route those to a second Virtual Audio Cable and then route that to your headphone port so you can monitor.
calamityjane on 12/14/2015(UTC)
Guest (4)
