jhebbel
#1 Posted : Friday, December 11, 2015 10:55:19 AM(UTC)
jhebbel
I think this was in previous versions as cut point, but when using a image sequence I no longer see the option to set when I want the transition to happen from preview to active shot. I am aware this can be made to work in a roundabout way using scripting and triggers, but then I would have to call the stinger as a overlay instead of making use of the center transition bar and the "Stinger 1" option.
TVIason
#2 Posted : Friday, December 11, 2015 10:58:19 AM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Did you click on the overlay button, select stinger 1 or 2 and chose your cut point from there?
If it's not working properly we can help you further
TVIason attached the following image(s):
stinger cut point.PNG (83kb) downloaded 5 time(s).
jhebbel
#3 Posted : Friday, December 11, 2015 12:02:52 PM(UTC)
jhebbel
:facepalm: completely missed the overlay button.... lol
