Setting transition point for stinger.
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
I think this was in previous versions as cut point, but when using a image sequence I no longer see the option to set when I want the transition to happen from preview to active shot. I am aware this can be made to work in a roundabout way using scripting and triggers, but then I would have to call the stinger as a overlay instead of making use of the center transition bar and the "Stinger 1" option.
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
Did you click on the overlay button, select stinger 1 or 2 and chose your cut point from there? If it's not working properly we can help you further TVIason attached the following image(s):  stinger cut point.PNG (83kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
:facepalm: completely missed the overlay button.... lol
