Hardware Compatibility
Capture card with 2 SDI in and 1 SDI out
Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
I'm looking to add a scorebug to a live switched hockey feed with VMIX using a live camera pointed at the arena scoreboard. I need to know of a capture card that can take 2 SDI signals in and output the VMIX program on SDI simultaneously. We are running everything in standard def 16:9 right now, so HD isn't necessary, though I know most cards today support it anyways. This is how I plan to use VMIX with 4 overlay channels to achieve this: Switched feed on the main layer Overlay 1 using scoreboard camera feed cropped to the time clock Overlay 2 using the scoreboard camera feed cropped to the home score Overlay 3 using the scoreboard camera feed cropped to the away score Overlay 4 using a custom scorebug "Title" graphic with text areas to put in the city abbreviations. (I know I might need to use some multiview trickery in order to use the same input source 3 times but I believe it can be done.) Then I want to take this combined feed out through SDI, it will then get distributed to a webcast & in-house TV screens. Here is an image showing what I am looking to do, as I said the time/scores would be a feed coming from a camera pointed at the arena scoreboard.
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
Is that the only option around that price or cheaper?
I see the decklink duo has 2 ins and 2 outs, is that limited to only 2 in or out at once? If so would a decklink duo work for the 2 capture and add a decklink mini monitor for the output?
Joined: 8/4/2015(UTC) Posts: 17   Thanks: 5 times Was thanked: 8 time(s) in 4 post(s)
Blackmagic decklink duo not full duplex card,work onli out or input. You need to use more mini monitor for output. I would have used the Blackmagic DeckLink HD Extreme 3, it can be used for the Title key + fill, since decklink duo does not synchronize properly concluded key + fill
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
swcreative wrote:Is that the only option around that price or cheaper?
I see the decklink duo has 2 ins and 2 outs, is that limited to only 2 in or out at once? If so would a decklink duo work for the 2 capture and add a decklink mini monitor for the output? If you have 3 PCI-express slots the cheapest and good working solution would be 2x decklink mini recorder + 1x decklink mini monitor. Plus you are not limited to SDI inputs (decklink duo), because mini recorders have HDMI inputs too.
